[4]
My Lathe Wont Start
[3]
[10] Like what you see?
BarnacleBill
Newbie
Aug 8, 2018
12
I have a HF 14inch mini lathe, I used it yesterday and it was fine, today it would not run when I turned it on.
I checked the fuse and the wires from the plug and there is continuity from the plug to the switch, I bypassed the switch and it still wont run.
I don't know what to check next.
Al 1
Active Member
Sep 11, 2011
102
Bill, is this a 120 volt AC motor? Try wiring the motor direct. The cap or motor may have taken a dump. Al.
pontiac428
H-M Supporter - Gold Member
Apr 23, 2018
388
The motor may be stopped between sectors on the armature. Maybe try a half turn on the motor by hand, then power it back up? Also see if there is a pushbutton breaker on the motor. These things are moot on expensive kit, but China savings brings China quirks.
eugene13
Nov 19, 2014
415
Does it have an emergency stop switch? Might need a reset.
Al 1
Active Member
Sep 11, 2011
102
Bill, I would double check all electrical connections. Check for hot spots, burnt wiring / connections. Al.
markba633csi
Gold
Apr 30, 2015
3,457
Another member mentioned there is a large coil (power line inductor)on the board which can become unsoldered
mark
Here is a repair service for those boards: www.olduhfguy.com
BaronJ
Brass
Aug 7, 2018
660
Hi Guys,
I had a similar problem on my mill, one minute it was working fine then it just stopped, display went out. It was just as if you switched off the power.
I banged the control unit and it came back to life. It ran for a day or so and then just wouldn't turn on. Banging the control unit didn't work this time, so I took it apart.
The wire was just pushed into the hole on the pcb. It was surrounded by solder underneath but obviously not actually connected.
A dab of flux and tinning it properly allowed it to be pushed back into the hole and soldered securely.
On testing the display no longer worked ! A little careful observation showed that the voltage regulator had taken a hit from the arc when I banged the control unit case. A 10 cent replacement cured that one.
I did find quite a number of bad soldered joints on the circuit board, which all got a seeing to.
[6]
[5] [7]
