My New Mill PM-45-PDF
mskobier
Mar 23, 2013
33
All,
I figured I might as well join in on the fun of posting about my new mill. It hasn't seen much use yet due to my work schedule, but that is about to change. Anyway, a few months ago, I purchased a PM-45-PDF. It arrived in good time, and I managed to get it unboxed and inspected. Everything looks great. I ran the motor for a few hours through each of the speeds to break in the gearbox. Since I needed to be able to move it around, I started designing a rolling stand for it. I did a lot of internet research looking at what others had done. I finally decided to design my own using some of the best features of what I had seen on the net. I am also going to add a powered head lift, and I am actively working on that mod at this time.
I purchased a powered cross feed for the x axis, and went to install it. Unfortunately the mounting bracket was approx. .030 too small and would not fit over the edge of the table. No problem, I indexed the vice, and clamped the bracket in it and took a hair over .015 off of the inside of both side of the bracket. It now fits as if it was made for it!
The rolling stand is made out of 2x2x3/16 square steel tubing. It is designed for the stand that came with the mill to sit inside the base and only raise the overall height by approx. 5". The leveling feet are positioned at 36" OAL for stability. I was deathly afraid of how top heavy this mill could be with the head all the way up. A friend does auto body work, and filled in the weld seams on the top, the ends, and painted it for me. He did a very nice job! I was just going to squirt some paint on it and call it good! The blue color was matched by the local auto paint supply and is called Fleet Blue. It matched almost perfectly!
I have also been building a fog buster type of coolant system. It is also almost finished. Just need to machine out the combining block and mount it up. The mill still has the flood coolant system, but I do not plan on using it at this time.
Anyway, here are a few pictures of what I have done so far.
Mitch
nice job. is that the wifes parking place you have taken ?
Congrats on the mill and nice, clean job on the base. Sugar talk over... Now get cut'n... (LOL)...
Ray
Davidh,
Actually it is my wifes side of the garage. I moved the mill there for the pictures. It is a two bay garage, and I occupy the other side. I didn't want to post a picture of all of my junk.... Uhh treasures! I am still in the process of cleaning out my side so there is room to store and use the mill.
Mitch
Excellent job on the stand! Looks great.
Now have some fun.
Gary
Excellent work on the stand! Congrats!
Hi,
I am also considering this mill for my first bench top machine.
Did you give any thought to getting the cast iron base for the machine?
My machinist friend and mentor has insisted that I use the cast iron to help
dampen vibrations. That's fine for him to say as he doesn't have to move it around!
But it makes perfect sense.
Anyone have a thought on that idea?
Dave
Dave,
The cast iron base is not all that heavy compared to the mill. It's not a feather but, it's not a solid block of metal either. I have no idea for certain but, I'll guess it weighs around 150-200lbs. Cast iron has absolutely remarkable ability to absorb vibration. Truly amazing stuff in that regard.
Ray
Hi,
Dave
Mitch,
Great looking set up!
I'm sure I'm not the only one.. do you have any plans or drawings you can share on that base?
dmakseyn,
Due to budget constraints, and the fact that the mill came with the stand, I did not seriously consider purchasing the cast iron base. In looking at the pictures and what little bit of the specifications I could find, I did not consider it worth the extra expense. I figured that if I needed a heavier stand, I could always build one that I thought was more suitable. The steel stand weighs about 100lbs anyway. The added rolling base adds another 100+ to that. I have some future plans on adding some narrow cabinets to either side of the existing stand, or build a new altogether.
daver,
No, I do not have any plans drawn up. I have a few sketches around somewhere that gives the general design. I'll try and find them and see if I can scan them so I can post them. The design is really pretty simple. I designed it around the cabinet that came with my mill. I'll see what I can do about finding the sketches. If I can not find them, I'll draw something up giving the major dimensions and the basic design.
Mitch
