Well that was generous of you. Nice looking lathe, your gonna enjoy getting it up and running.
Just got it off the truck and on a cart ..... guy was asking $325 off of CL ..... I gave him $350 because I felt bad!
Lot of tooling, spare gears and original parts list! Looks to be a 1942 model.
Is the tapper complete ??? if you only have the tail slot I would be willing to trade you a standard ceoss slide plus $50.00 cash.
Joebiplane
joe@oldetimemachines.com
After looking at what you have done with yours ..... I'm thinking of sending this on to Casa Grande for some sprucing up .....)
Thanks for the kind words. Not sure how far you are going with your new addition, but if you need to strip paint, use aircraft stripper. It is in a blue can and you can get it at O'reilly's. It works in minutes and is cleaned up with water. It works amazingly well. If you need to de-rust anything, use Evaporust. It is 19.99 a gallon at Oreilly's and it also works amazingly well. If you were closer I would gladly give you a hand, but you will get a great deal of pleasure doing it yourself.
What is the pull out pin (next to the forward/reverse lever) in the head stock for? I can see it engages two lower gears but I'm unsure of their purpose.
I am pretty sure its like mine and it engages the back gears which slows the lathe RPMs down for slower cuts. It should have a pin that when pulled out locks the lever against the head stock so it won't go back in. To disengage you push the pin in before pushing the lever back in. It is on the under side of the lever so feel for it. Also there is probably a pin in the bull gear that has to be pulled out to disengage the bull gear from the pulleys. The bull gear is the big gear on the front of the spindle shaft.
