- Dec 12, 2014
- 261
...continuing the process...
A few things I have learned along the way.
- Wiping the surface plate with YOUR HAND is IMPORTANT!!!
- It finally makes sense, leave a distance between each row of scrape marks. This is approximately the same width/length of your scrape marks. This creates the checkered pattern and evens out the highs and lows. Hope that makes sense.
- It's very easy to screw up the distance between scrape marks with a power scraper. You actually have to move the scraper relatively fast across the part to avoid this pitfall. **You will see me make this mistake in the video**
- As pointed out before, DON'T make scrape marks directly side-by-side!!
