need a gear made
irishwoodsman
Nov 19, 2011
966
any members set up to machine me a new gear, dont mind paying, 72 teeth 16DP 4-5/8". diam:biggrin:
Making gears was to be a winter project for me, but not there yet, sorry, but I am sure someone will chime in soon. I just turned down a 3" dia. brass gear today. Maybe check with places like Boston gear or McMaster-Carr to see if they have them. I did work in a shop that had a automatic gear maker, just plug in the info install the right blank and let her rip, come back in a little while and it was done. The shop is no longer there and I do wonder who got that machine.
Paul
i found a shop local here after making alot of calls and as it turns out it is a idler gear and i got the specs from the sheldon lathe site on yahoo. 60.00 for the blank gear with teeth and i machine the relief cuts and exspand the center hole or they make complete gear for 200.00 flat fee, but ty so much for trying to help, thats what i like love about this site:biggrin:[h=1]Brewer Bearing & Gear Company[/h]
  • (314) 534-4021
Dang, $200 for a complete gear? I'm too cheap for that. :whistle: Perfect excuse to go buy more machinery in order to be able to cut my own. :biggrin: "But Hon, I saved $200 by making it myself!!!" :biggrin:
-Ron
no, but i will now since i got the specs on it. thanks for the info. sometimes you get between a rock and a hard spot especially if you dont have all the tools and your at their mercy:phew:
Depending on the pressure angle, try PN S1672.
is this the gear number and by whom is it made and has it. ty tony:biggrin: 72 teeth,16DP is 4-5/8" diam
Yup, that's a part number used by Martin. Ed located you a couple of sources. You need to be sure about your pressure angle though. That part number is for a 14 1/2 deg PA. Cheaper than having one made, but you still need to bore it to size, etc. Might need to face to width for example.
sorry for the late responce, rough night. i looked at the gears and their not close to mine, i will try and get some pics up maybe that can help define what i have:thinking:
