- Oct 17, 2018
- 922
LATHE #2
Lathe #2 is way too big for where I need to put it. The height and length are not a problem, but the depth is. I have a 24" deep bench top and the lathe is 30" deep. I cannot modify the bench or put the lathe anywhere else; it must go where the Atlas Craftsman is now.
LATHE #1
So that leaves lathe #1. I looked up the G4000 and change gears are $84. I find it odd that this lathe has a QCGB, but still needs change gears. At least these just need light oil and not grease. And the QCGB is for feed speeds, which is one reason I'm even considering buying this. I could get the change gears from Grizzly as long as they have the same hole size.
The follow rest is not available for a G4000. 1. Are accessories available anywhere else?
2. What type of plug does it have (see pictures)? I looked it up and it seems to have a locking 220V. The seller states it was tested, but buyers need to bring an adapter. 3. How would I test this? Maybe bring a regular plug with bare wires at the end that I connect to the plug prongs on the one on the lathe? It makes we wonder if this is wired for 220 and not 110. I don't have 220. The G4000 is 110 and there doesn't appear to be an option to wire it for 220, at least not in the user manual.
4. Does this use an AXA tool post?
5. What other questions should I ask about this particular model and this particular machine?
LATHE #1
