- Jan 27, 2020
- 8
These bars came with my 1939 South Bend 9" Workshop lathe.
They are 5"s long and 1/2" diameter. One bar is stamped on the end with a shield and the words STANDARD 8616.
the other is stamped 1/2" STANDARD TOOL CO. and 52941. Both bars measure .504 on one end and .500 on the other. they are center drilled on each end.
The three collars are all approximately 1" long (one is dead on the othere are 1.007 and 1.016) One collar has a .438 bore and the slot is .062 dp.
The second collar has a .3125 bore and a slot .140 dp. The last collar has a .250 bore and a .175 dp slot.
