- Dec 29, 2013
- 284
Anybody have the slightest idea on how to remove the y axis lead screw on this? It is a G.Dufour 51 I believe. I had the knee off but put it back on today so I could move it up and down easier. I have/have had everything else off but I cant figure this lead screw out. It has all the gears inside the knee that allows for multi or simultaneous power feed from a single motor, but I'm not using any of it. I have all the gears loose on the shaft but cant get it to move.
Reason why, is I need to replace the bearings on the front and would like to take the extra gears from inside since I wojt be using them.
The shaft does not tie into the back of the casting.
There are other shafts in there behind the oilers on the front, but I dont know how to get them out either. nothing is secured from the backside of the knee. I double checked before putting it back on this morning.
