Hey y'all Bridgeport folks out there, Bought this mill almost a couple of years ago and been using it every since. Pretty much daily. I changed it over to a 220v single phase with single phase 110v power feed on the left/right table axis. The mill runs fine in all 4 low speeds. When I move the hi/lo lever to the forward (A) position, then rotate the pulleys by hand until I hear/feel the clutch engage, then move the side lever to IN and turn it on, it's makes the loudest racket I've every heard. Like it's trying to disengage and the teeth are smacking each other. Strange, as SOMETIMES it will actually go into the high range, but the motor tends to smell hot, like there's some kinda drag on it while it is in the high range???
Anyone like to give me some advice ? I can remove the motor,adapter plate,belt cover, motor pulley, etc; very easily. What's next to remove, so I can see what the problem is and correct it? I need to use the high speeds often, but am far more times than not, stuck with having to use only the fastest of the 4 slow speeds.
Thanks y'all
Mutt in North Texas
Thanks y'all
Mutt in North Texas
