Need someone to make a couple drawings from my rough sketches.
The slot stops 1/8" from the surface of the web.
I held a 1/4 drill rod in the slot and inserted bits under it to come up with that measurement.
I think they call this "reverse engineering"
like the Russians did in WWII with a captured B-29.
Here is the STEP model (3D). Working on finishing the drawing.
  • Part1.STEP
Got caught up at work a bit late. Here is your PDF of the drawing. Double check the dimensions and let me know if you'd like any additional info on it (material, chamfers, surface finishes, etc.).
Cheers,
-Mike
  • Part1.PDF
WOW!!
That is awesome!!
What, if anything, might I do for you in return??
Thank You, Thank You!!
I picked up a scrap piece of 3" shafting that I am using for these.
It had bearings and keyways on one end that were trashed.
About 36" of usable material once that end was removed.
I hope it is of sufficient quality.
Note, I took a look at this drawing and saw I missed the 0.250" dimension for the depth. I have gone back to the previous post, deleted the original PDF and replaced it with a new version. Sorry about that. Guess it is what I get for doing that right after work!
