[4]
Need t-nut milled
[3]
[10] Like what you see?
GunsOfNavarone
H-M Supporter - Gold Member
Jun 26, 2018
276
Hey all!
So I just got the lathe....cut the t-nut on the basic facing cut but I cannot figure out how to cut the nut without causing a collision for the stepped part of the operation. Probably need to do more basic stuff to learn this a bit more. Anyway, I know I haven't been here long but was hoping I could get someone to mill the step into this t-nut for me.
Thank you kindly!
GunsOfNavarone
Jun 26, 2018
276
Mill is next...maybe within a month or two, I was unaware of milling attachment for a lathe...or do you.mean a lathe/mill combo? Still, no mill either way...hence the "can you make something for me" thread...
RJSakowski
Feb 1, 2015
3,897
Hey all!
Thank you kindly!
You can make a nut on the lathe. Turn the boss and flange and tap your threaded hole. Remove the nut and cut the sides to fit your T slot.
GunsOfNavarone
Jun 26, 2018
276
Yup. I tried different jaw positions and spacing it out away from chuck, can't really find a way without a collision happening, either tool hitting jaws, compound hitting chuck etc...
jdedmon91
Active Member
Dec 29, 2017
493
Hey all!
Thank you kindly!
I have a better suggestion. Measure the dimension of the that you need the T Nut made at. PM me with the dimensions or better yet make a sketch of the t nut with the dimensions. When I get home Sat I’ll check and see if I have a suitable piece of stock and just make one. That way I only have one way postage in it.
TerryH
I have no clue what I'm doing...
May 8, 2018
332
Tee nut as in the one for the tool post? Assume you are changing to a QCTP? I've been researching as I pick up my new to me G0752 in a few days. I see guys that just drilled and tapped the existing nut to accept the new stud for the QCTP. Is that a possibility?
GunsOfNavarone
Jun 26, 2018
276
Thanks JD and to all with the pointing out what the nut looks like made on mill. I am aware of the final.product, but the pathway isn't so clear... I have literally ran this lathe for 1/2 hour. If there was more clearance on this job, that be great, but free styling this early in the game is risky...I can see it.
GunsOfNavarone
Jun 26, 2018
276
it is an option, if there isn't another answer, I can go this route.
RJSakowski
Feb 1, 2015
3,897
If I were making the nut on the lathe, I would turn the boss and drill and tap the hole for the stud. Then I would flip the part in the lathe either using the stud as a mandrel or mounting the boss in the chick . Then I would turn and face the flange to dimension. Finally remove the nut and cut the flats with a hack saw or band saw and file to fit the compound T slot.
The height of the boss must be less than the the thickness of the upper wall of the T slot and the height of the flange must be less than the lower wall of the T slot , The diameter of the boss has to fit the T slot as do the distance across the flat but nothing is really critical.
GunsOfNavarone
Jun 26, 2018
276
RJ, thanks for more of a process layout, that helps. Is it completely stupid that I really want a rectangular one and not a rounded one? I mean support strength isn't a huge issue i know....I just think it would be day and night keeping chips and crud out of there if there was no open space for it to get there. I guess I gotta.do whatever works at the end of the day. though JD's offer is very tempting...I'll have to see what stock o have laying around.
GunsOfNavarone
Jun 26, 2018
276
Working through it, I'll let you all know if the final product flys! If not I'll tap my stock one, but I very much appreciate the offers, super helpful!
kvt
Oct 21, 2014
2,067
Now when you finally get your mill or milling attachment, you can make others as you wanted but That one should work fine from the looks of it.
GunsOfNavarone
Jun 26, 2018
276
I'm finding myself calibrating, adjusting, leveling, massaging twist out. It's a full time job! I need to just spend 8 hours getting everything right and then making stuff. I adjust one thing, work on a project then come back and work on perfecting another adjustment...just endless.
[6]
[5] [7]
