- Jan 23, 2011
- 246
I got a steel shaft that is 0.469 and a gear that is 0.465 . The shaft has has a half moon key that goes in it. I need to install the gear on the shaft. I can't use any heat because the shaft has a bearing and a seal already installed .So will dry ice shrink the shaft enough so I can install the gear. Thank you for any info
