- Mar 3, 2017
- 738
I'm not sure how nickel silver works in stamped sheet-metal (nickels are coined, though, so it can't be impossible),I had 3D printed versions of my guitar pickup covers made... wanting these covers in nickel silver metal
but if you have 3D print of the shape, can you use that to make forms for casting, or even
lost-wax style?
Multiple dies would likely be required to make a deep-drawn shape, but sometimes those aren't expensive
at all: one technique presses the sheet with a block of rubber against the die, so there's only one hard item
for each of the successive forming steps. Annealing between operations is required, and that kiind of
die-forming doesn't make apertures, as I understand it.
