- Jul 28, 2017
- 2,367
We won't know until we have some hardware and time to play with it. I doubt the Theremino/MCA implementation uses a track/hold, possibly it's doing something similar to what you're suggesting. If so a sample rate of ~40KHz might be sufficient.There are high speed op-amp circuits that can ride up a pulse, and stay stuck at it's peak until discharged. I will agree the scheme has the merit of low cost simplicity. It has been a while since I used LTC6244. They are now part of Analog Devices.
--> PEAK DETECTION
I think the nature of the pulse - how sharp, or broad is it, or is it two pulses partly overlapping, is better to know than to just seek it's peak. We now have low cost high bandwidth A/D conversion chips available that can capture a pulse with enough samples through it's duration to get it's shape, including it's peak. Should we consider a pulse trigger circuit which starts a sampling, capturing (say) a gated 1second's worth at some sample rate like 250KHz?
If the pulse is faster, we increase the sample rate, and maybe reduce the sample interval.
The case of two overlapping but different-energy photons could be a difficult nut to crack. If you have a quantity C = A + B but you don't know A and B, the possible solutions are infinite. This is worst-case though, because you know, in general, what set of elements could be present. The algorithm would have to be informed by the set of possible photon energies. This is not an unusual approach to take -- the EDX S/W I've used gives you the option of selecting an element and telling the S/W that it HAS to be present; or tell it that its guess at an element is totally wrong. I've seen the S/W think that something like Europium or Hafnium is present and that just wasn't possible.
