I am still trawling everything there is about material identification, learning about Raman handheld spectrometers, finding out about Compton scattering, and what is an Auger electron, and why that produces a special little piece of spectrum.
In the most practical way, I am still only seeking to winkle out some scheme to cook up a materials identification gadget, simple, and very cheap, and can be made by most HM members, perhaps with some help between them.
I was thinking shining an IR laser diode salvaged from outdated CD/DVD units, and using a $1 avalanche photo-diode from Mouser.com, or DigiKey might have possibilities, but I am not plugging for anything definite yet, until I know more of the physics, and what property we are trying to exploit.
If it has to be bombarding the steel with ex smoke detector radiation, then fine. Now what wavelengths come back, and how do we use them? If we use some other energy, IR, whatever, that is a new game.
Re: The diaphragm vacuum pumps, I have actually used a dual-diaphragm type at a place I worked, but now I forget the brand name.
My usual fare was industrial sized tandem vane pumps, with very large diameter valve openings to oil diffusion pumps, or sometimes turbo-molecular pumps. With all the Edwards vacuum gauge kit, and pump-down sequence logic instrumentation, they come expensive! The change-over from hot-wire Pirani bridge gauges to Penning ion gauges comes at about 10E-3mbar, where there is not enough gas to keep the hot wire working. There was one type which could "bridge the gap", getting to part way to 10E-4mbar.
Then I found the small dual-diaphragm non-oil pump, and it really could make low-grade vacuum, certainly up to 10E-2mbar. If I find it again, I will post it.
