New Grizzly Lathe And Mill
drtho999
Sep 25, 2014
14
I just got my new G0494 16x60 lathe and G9904 10x54 Mill. I installed the 2 axis DRO from Dropros on the lathe. Have not had time to do anything other that install and level. I got the lathe within 0.0002 on the X axis and within o.001 on the Z. I installed the machine feet with the rubber base from grizzly. Does anybody have any experience with these types of leveling feet? How often should you check level? I have a 4 axis DRO for the mill and will install it as soon as I get time. Any tips on installation? This is my first post so I am not sure how this works. I have multiple questions about these machines. The Lathe was suppose to come with the 400 series QC tool post but it arrived with the 300 series. Is there any real advantage of having the 400 series?
20150706_133105.jpg 20150706_161831.jpg 20150706_202413.jpg 20150707_092125.jpg 20150707_104524.jpg 20150707_123953.jpg 20150707_131139.jpg 20150730_125144.jpg
That's a hell of a 1st post congrats! That lathe now that's what I'm talking about size wize :encourage: Also, your Kubota tractor dwarfs my B2920 how much can that FEL lift?
I have the rubber machine mounts under my Grizzly mill and they stay on level very well. Check about once a year and no change at all == Jack
Very nice, massive. There was some recent discussion about using rubber feet on lathes, and it was supposedly a No No. I had mason feet metal cup with a rubber pad under it, but just bought some steel leveling feet to replace it. My previous rubber ones did fail on the lathe, they work fine on the mill. I have seen specially designed isolator pads for CNC lathes, very expensive. You should have a 400 series (15-20" swing) or CXA (14-17") QCTP, it will allow bigger tool holders.
Wow, nice setup! Drool worthy. You'll have good times with those machines.
Nice Machines. :D
Wish I had a use for something that big and could afford them too.
Great line up of equipment, I wished my shop was large enough to accommodate larger equipment. Bob
Nice!
I bought it's smaller cousin G0516 last week. Yours is a big'un!
The FEL is rated at 3600. The Mill was all it wanted to lift and that was with the bucket all the way flexed in. Had to lift the lathe one end at a time and roll it off the trailer.
