New mill Wells-Index 745
Thanks, I'm doing my best. Sorry if progress is a little slow. I have a young family so between that and work I don't get to too much time, i've also been sick lately too.
Once I finish refurbishing the parts in the top of the head I will have a look at the lower part of the head and post some pictures.
What does that fork your trying to install do?
I am sorry to be such a pain. I remember young ones and the hassles of life.
This is the clutch lever for the downfeed. I took it apart a while back and I don't remember how it went back together.
The clutch adjustment eccentric is drilled off center. I know it came out without any trouble.
No worries, I know it is frustrating to be stalled on a project when something goes wrong (won't go. back together).
I work saturday's so I won't have time tomorrow but I will see if I can find some time this week to take a few pictures of the down feed mechanism on the head.
Hi Guys, so a bit of bad news my phone died without warning today, which means I have no camera to take any pictures. I had planned to photograph the disassembly of the head today, but with no phone/camera that was not possible. This afternoon was the only time I had available to work on the mill this week. Sorry Azshadeguy I wanted to help you out but looks like it will have to wait until next weekend/week. On the positive side I used my time today to get the final color coat put on the parts of the upper head, so the upper head is ready to be reassembled once the paint hardens up.
No problem Thanks for trying.
I was looking at the thead about the model 845 and it looks like the head is the same.
There are diagrams on the web for the 845 that a lot more detailed than the manual I have for the 745
Hi guys, sorry its been a while I don't get much time in the workshop. However with what time I have I am still plotting along on the 745.
Since I don't want to many parts laying around the shop, I figured I would put the top of the head back together before dealing with the lower head.
a few pictures of the process....
292227
292228
292229
292230
292231
I made sure to clean-out and re-greese all the bearing and put a bit of oil on all the gears.
I need to get a keyway before I can put the one pulley on...but other than that the upper head is all ready to go.
292232
Slowly but surely I'll get this machine back into working shape.
I am really liking that color you are painting the mill.
What kind of rivets did you use to reattach the nameplate with?
Thanks Azshadeguy. So far I had been able to reuse all of the original rivets/pins that held the tags on.
However, I just noticed this week that one rivet/pin went missing off my work bench and I could not find it so I need to figure out where I can get a new one. If anyone has any suggestions they would be welcomed.
Hi Guys so I am finally getting started on the lower head tear down. The head on my machine was in working order with everything functioning so this should be a good guide for anyone needing to see how the 745 head is put together.
Here's the lower head
292606
Top view...
292607
292608
This handle moves the exposed gear up and down...
292610
292611
292612
292613
The first order of business was to remove the exposed gear. I first removed the pin and set screw that hold the handle to the shaft as well as the set screw that retains the shaft.
292609
After you disengage the mechanism from the gear you can pull the gear out...
292614
292615
292617
292616
Here is what it looks like with the gear removed...
292618
Next up was this....
292619
To remove the handle there is a pin you must remove and a set screw you must loosen...
292620
Cover plate removed...
292621
292622
The mechanism can be taken right out without any further work...
292623
292624
Its pretty hard to see with all the grease so I cleaned everything up so you guys can see what the actual parts look like...
292625
292626292627
I will post more tear down pictures in a little bit when I get time...
292631
292632
292633
292634
292639
292636
292646
292637
292638
292640
With the grease cleaned off...
292643
292641
292642
292645
292635
besure to remove the set screw on the 'dough nut' that is on the threaded shaft...
292644
There is a little retaining snap ring at the bottom of the threaded shaft that muat be removed....
292647
Then drive the shaft out the bottom...
292648
292649
292650
