- Nov 5, 2016
- 1,419
My project list for my new to me South Bend 13" lathe is getting a lot shorter!
I just recently got this lathe and it came with its' original Reliance 2HP 3-phase 230 volt motor. That motor, for some reason, just didn't like running on a VFD. It made a lot of the typical VFD motor whining like some do and also would do a little growling at times. Here's the kicker... the input amperage on the 220 volt single phase side was around 3.5 amps per leg. But, the output current (at the same voltage and running at 60 Hz) was around 9.5 amps per leg! The motor would get extremely hot after running it for a while and so I contacted FactoryMation tech support since that is where I got the VFD.
He didn't have too much to offer other than checking a few things out and said that one possibility was harmonics. I swapped out the VFD with the one off my Bridgeport (which was running fine; same HP as the lathe's motor) and the problem stayed with the motor and didn't move to the Bridgeport. Clearing the VFD as the problem, I decided to buy a new motor. Now, there are more 3 phase motors available than you can shake a stick at with prices all over the map. But, after doing some research I bought this guy:
Siemens 1LE21111AB414AA3 2-HP 230/460 volt inverter duty motor. It's a Simotics General Purpose NEMA premium type GP100A with an aluminum body/frame and copper rotor; high efficiency, fully enclosed, fan cooled TEFC.
No whine at all. At no load, draws less than 2 amps even when down to 24 Hz. Time will tell, but right now seems to be a winner!
Ted
Ted
