[4]
New PM 1440-GT
[3]
[10] Like what you see?
wrmiller
Chief Tinkerer
Mar 21, 2013
3,508
Very nice. :)
I have a VFD on both my 935TS and my 1340GT, and will say that the lathe is the more complex of the two to install a VFD on. I originally did my own install, but later bought a setup from Mark as I wanted his electronic stop.
You'll love having the VFD on the lathe. It just makes dialing in the cut so much easier.
scott55
New Member
Jan 12, 2017
21
I have the 940-TS and now the 1440-GT.
I did the 940 VFD on my own and it was not too bad.
I used the Fuji VFD on that one because I did not know Matt had such a good deal on the Hitachi, and that there was more info available on the Hitachi here.
I got the Hitachi for the lathe and I am thinking of just gutting the electrical system and wiring the lathe switches directly to the VFD, but I am only at the thinking stage so far.
I do have to say the Fuji manual is rather cryptic about a lot of the settings
I have not dug into the Hitachi manual just yet, only got the machine Thursday.
What are the advantages of keeping any of the factory relays/wiring etc.?
Also what is the "setup" you bought from Mark?
thanks,
Scott
mksj
Jun 12, 2014
2,083
I do not recommend wiring the VFD directly to the spindle controls for safety reasons and you are also do not take into account the foot brake, E-Stop or any of the other safety features. I had previous outline a very simple conversion (basic) which uses the contactors to switch the VFD inputs and also maintains all the safety features of the lathe. Each 1440GT seems to have some variants on wiring, so you need to have a basic understanding of what your are doing in the conversion. With the foot brake, you should issue what is know as a free run command to the VFD which negates the VFD braking when using the foot brake. This requires replacing the brake switch form a single pole to a dual pole, one side trips the power realy (default) the other side issues a free run command to the VFD. Otherwise they will fight each other. Note, the VFD input run commands are completely separate from the machine low voltage circuit. The details of the conversion and programming have been outlined in the following thread:
https://www.hobby-machinist.com/threads/pm-1440gt-basic-wiring-changes-for-using-the-contactors-to-switch-the-vfd-inputs.64965/
You must use an external braking resistor with the VFD on a lathe, there is too much momentum otherwise. There have also been other postings with suggestions as to VFD cabinets, venting, switch gear and fusing. If you can't find it send me a PM with your email and I can send the files.
Mark
Nogoingback
Oct 18, 2016
1,191
thanks,
Scott
I have a Hitachi VFD on my lathe. Despite the having no prior experience with VFD's, I had no trouble
programming it after studying the manual a bit. I'd say it's pretty well written.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,508
thanks,
Scott
Speaking of Mark (mksj), and here he is. :)
I would take him up on his offer to send you the files. Plus, he's a wiz at programming these things. I do not know if he is still making control systems for folks though. You could ask.
scott55
New Member
Jan 12, 2017
21
Mark
Thank you for your help.
I got it up and running. Still waiting on parts to finish it like I want but it is usable at this point.
Just cut a test bar and cannot measure any difference over 4" with a tenths mic, so I guess my first attempt at leveling went ok.
I am very impressed with the machine as I expected from a PM Taiwanese unit.
Scott
Janderso
Jeff Anderson
H-M Platinum Supporter ($50)
Mar 26, 2018
1,293
I may go with your exact lathe when I retire in a few years. meanwhile, i'm improving my skills on the old South Bend.
Nice Lathe!!
I am very jealous!
scott55
New Member
Jan 12, 2017
21
Nice Lathe!!
I am very jealous!
Thanks,
So far I am very impressed with it.
The main thing I have learned so far is you can never have enough tool holders.
Janderso
Jeff Anderson
Mar 26, 2018
1,293
I have found that out. You need plenty.
Show us your first projects.
Spotshooter
Dec 28, 2018
35
I’ll be ordering my 1440GT by March, and I’ll go the VFD route as well.. pretty exciting, congrats on the new lathe !
petertha
Jan 15, 2016
700
jbolt, is that a solid block (compound replacement) under your toolpost among the swarf? If so I'm mulling over a design for my lathe as we speak. Did you document this anywhere I can see what you did? I'm collecting thoughts & wisdom from a few other folks who have done this (Stefan.G, Rob.R David.B).
jbolt
Dec 3, 2013
1,563
Yes, I documented it in this thread.
https://www.hobby-machinist.com/threads/cxa-qctp-on-the-pm-1440gt.57630
I have only used my compound once since making the solid riser. For most short tapers I use HSS tool bits ground to the angle I need.
Sent from my SM-G955U using Tapatalk
[6]
[5] [7]
