- Oct 31, 2015
- 466
Thanks. It has worked well for me, and I'm happy that I bought it and spent the time on it. That said, every machine has its weaknesses and this one has its fair share. Here are a few of the things I don't like about it:
- Small spindle through hole (25/32") - limits the size of stock that can pass through and doesn't allow for using 5c collets in the spindle nose.
- Plain apron - all feeding is powered by the lead screw. Also, no clutch.
- As a result of the above, the finest feed is 0.004" per revolution. I often wish for a finer feed to produce a better surface finish.
- Underpowered. Mine has a 1/2 HP motor (which is what the machine is spec'ed for). You're not going to be doing any "hogging"
