Ive finally got one after years of wanting a small lathe, its in quite good shape, it had a bit of surface rust that cleaned up with some wirewool and WD40, has also quite a few accessories, some are new. I need to know what that part is called (red arrow) someone had put an allen key bolt through there I would like the quick release set-up if poss so I can change the angle of the cutter
