Resolved Newbie needs help on how to post and add photos to posts
If you haven't made a donation to this site you can only edit it for a few minutes after you make the post. If you make a donation, depending on how much you make you have more time to go back and edit your posts.
To add photos you use the attach files button.
Upvote 0
You can edit for 2880 mins (2 days). After that, a moderator will be glad to do it for you.
That had to be done because several people, when they left, decided to xxxx out all their posts and all the info in them.
Upvote 0
According to the site, you have 30 min if your a free member, 1440 if you donate $10.00, 2880 if donate $25.00 and unlimited if you donate $50.00 . So, as Nelson said you have 2880 because you donated.
Upvote 0
Note however that editing or adding to an existing post does not reset any ones Alert status for that thread. So if someone had already read your post, they may or may not ever read the edited version. I would therefore recommend that you limit adding to an existing post to the first few minutes after you saved it. If you later remember something that you meant to write, and there are no other posts yet following your last one, just do a new post. If there are two or more posts following the one where you had intended to add something else, on the right edge of the screen just below what you already wrote, click on Reply, which will drop you to the end of the thread and copy your incomplete previous post onto the top of your new post for you. And anyone who was watching that thread will get a new alert if they had already read your original (assuming of course that they have Alerts turned on.
Upvote 0
