Hi all,
Howdy and a quick intro:
First post and new to milling...so warning up front!!
Been on a spending spree today and after much fretting ended up with a 759 on its way to our door.
My 17yr old son and I will be using it primarily to mill renshape to make positive masters for silicon molds. The subject material: 25-52mm wargaming pieces. While we have an ultra-high rez DLP 3d-Printer, its limited on size of pieces and speed/cost of printing come into play, so a mill seems like a great fit.
While I've done hobbiest woodwork and welding for 30+ years and he's been scratch building scale models for competition for 6 years, this is our first venture into milling. Been doing every type of convoluted cut on tablesaw/bandsaw/jigsaw/handsaw/Foredom you can image. Looking to the mill to bring more accuracy and safety to the picture.Likely we'll be asking a few questions along the way! I'll go ahead and say "thank you" ahead of time in case I ever forget to tell someone thanks along the way...old-timers disease sets in from time to time ;-)
Noticed the base for the 759 looks...mmmmm...shall we saw "underwhelming". While I'm waiting for it to arrive, I'm designing a new base for it, a variation based on what I saw on russstuff youtube channel. Key differences will be slightly taller (my son and I are both 6'+....and I dislike bending over for long periods anymore), wider (I plan to add three drawers underneath, no wet area as russtuff had since renshape vs steel, more likely a vacuum attachment), and plan to have lengthened 2x6 outriggers to running across bottom front and back...outside the corner legs I'll have the leveling bolts for ease of access and also plan to put 3-4" casters....a rule of my shop is everything has to be on wheels.
So now that I'm sure that's clear as mud, this particular question
Q) what is the dimension from the bottom of the mill base to the top of the table? From pics I'm guessing its about 8"??
If so, following russtuffs dimensions looks like it'd put the top of the table around 38.5"ish (36 legs + 1.5" top + 8" for table height)..given he stated he's about 5'10".. for us, I'd add 3-4 inches to that to get a table height of around 41"ish range.
TIA,
Jesse/Jon-Luc
TIA,
Jesse/Jon-Luc
