- Feb 20, 2012
- 77
I'm making a vacuum chuck adapter for my woodworking lathe. I need to get a seal as my adapter fits inside a 10mm bore.
I've searched most of the threads here that mention O-rings, and tried out several of the on-line O-ring calculators that were mentioned in those threads. If I stick to standard sizes (ISO 3601, or AS586), I end up with a design that either (1) stretches a 011 to its limits, or (2) has a very loose fit with an 012.
Any suggestions? All info and comments appreciated.
( Here are the nitty gritty details, if you want to try your hand at the design. Bore is 10mm nominal. I don't have a set of pin gauges, but using drill bits as feelers, I get a loose fit with an X drill at 0.393, and a no-go with a Y drill at 0.401. Those are the actual measured sizes; I know the nominal hole they drill is 3-4 thou larger.
The adaptor carries the O-ring grooves on its outside; it is the male part of the junction.
This is for vacuum, so pressures are low, and this is a static fit.)
