I’ve been following this thread and being inexperienced , trying to learn . The issue is he dials a certain amount and doesn’t get the correct outcome. I’m trying to figure out how the wear in the ways are causing his problem? I can understand if there’s wear along the ways the cuts might cut a taper . A hypothetical job , say 2” shaft and a 1” cut along it he touches off takes a he takes a .010” doc on his dial . He measures needing another .008” on a side , he dials that and getting something different? Wouldn’t that be a different problem, slop in the crossslide , compound or others ?
