- Oct 31, 2014
- 444
Greetings all,
We have an Onan 12.5 KW 4-cylinder natural gas power plant as our standby power source.
It usually lives under a rainproof cover and has been trouble free for years. We are having the house painted and I removed the generator cover so the painters could more easily paint the siding behind the generator.
It rained quite a bit whilst the gennie was not covered. When I fired it up for its monthly test it started right up, sounded fine and then died after about 10 seconds.
Checking the oil dipstick the crankcase seemed to be overflowing with a whitish oil/water emulsion. Ugh.
So, nothing ventured, nothing gained. Trying to salvage the unit I drained the oil and the crankcase had a couple of gallons of water along with the oil. Double ugh.
I replaced the filter, poured in enoiugh oil to get onto the dipstick and cranked her over. Eventually, after a lot of wheezing and other unpleasantness she started running and eventually sounded pretty normal. I figure the residual water that was in there after draining will be diluting and contaminating the oil so I will run it for a while to get all the water suspended and then drain and refill with fresh oil again - along with another filter change.
So, now to my question: How did all that water get into the crankcase? There's no obvious open filler neck. PCV valve or other place for rain to infiltrate into the crankcase.
I'd like to avoid such unpleasantness in the future but so far I'm stumped as to the water source. Any ideas?
Thanks in advance,
Stu
Thanks in advance,
Stu
