- Apr 14, 2014
- 3,140
Like Bob for most general turning work it's fast and simple to just use the 6" scale. If you need to be dead on center for facing take a piece of scrap and do a facing cut. If there's a nipple left adjust the tool up or down to get on perfect center. Once you hit perfect center the face should be smooth from one side to the other. If you're using quick change tooling lock the adjusting nut in place. The tool should remain on center. About the only way it would be off center is if you had run out in the chuck, a poor quality tool post or holder, or stock that isn't truly round.
In all my years in a machine shop I've never used a depth mic to find center, and I've never seen anyone else do it either.
