...one more thing......
I have had decent results using windows built-in System File Check "sfc".
It can sometimes find corrupt system software components and repair/replace them......
Here's a link:
https://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
That is definitely worth a shot.
-brino
Good idea recommending SFC, didn't think of that at 3am.
I've encountered the print spooler problem several times over the years and it always seems to be something different.
If nothing else is acting up on the system this is fixable.
My daily driver is still win7 also. I've got win10 installed on (2) laptops and (2) towers, the two towers are identical hardware yet win10 does not behave the same on both. Updates are different and the Build Numbers are different.
Micro$oft can't get their act together at all in regards to updates. Most blatant of all is when you really need to use your system and it decides it needs to update instead, and you're left sitting there with hat in hand.
My Son is Sys-Admin'ing over (400) seats and I'm not at all sure how he is keeping his sanity.
And then there is the 'phoning home' aspect. One has to tweak the hell out of the system to keep M$ out of your shorts.
In 30+ years of dinking around with M$ products I've never seen an OS release behave so erratically. But then I didn't touch win8...
Ease up on the 'system restores' - me personally I've had mixed results with that fine feature.
Do the SFC check on the system and let's go from there.
After that it's time to run chkdsk (check disk) per
@Forty Niner's recommendation.
