My PM1030V has been giving me much enjoyment for like two years now. Not that I really understand anything about the machine or machining, but I like what make.
And then, yesterday, something broke.
As I said, I an real amateur. So, I am hoping there is just some selection/gizmo on the machine I had not previously noted. But maybe something is broken I need help in learning how to get it fixed.
Suddenly, I can’t move the carriage. Hand wheel will not turn. I have checked that the carriage lock screw is loose. Half nut engage lever for threading is not engaged. Cross-feed and longitudinal feed lever still clicks into all four positions as normal. Further, the leadscrew is no longer turning even though the coupling sleeve coming out of the gearbox assembly does turn. I guess that means the Taper Pin connecting the two has sheared (what a nice fail safe feature).
So I think something in the Apron Assembly is not working right.
Question 1: Any thoughts as to what might be wrong and thus, how to fix?
Question 2: How do I find an experienced repair person to hire to fix something like this? (I accept that real machinists can disassemble/reassemble and for that matter, make from scratch, all their machines. I just want to use it, I will never have the skills to do heavy maintanence on it. So, want to hire some expertise here.)
Thank you, as always.
-Bill
-Bill
