I have used POR-15 before on some of my cars etc....that is tough stuff. One time I put it on something I later changed my mind and tried sanding as well as sand blasting. That stuff just did not want to come off!
I will go with the Krylon rattle can as it will atomize where as the POR-15 doesn’t.
When you clean the pla right before spraying make sure to GENTLY wipe the surface (isopropyl alcohol is what i use), DO NOT SCRUB the surface. If you scub you risk bring Unwanted release agents or other oily residue to the surface that the paint will not stick to and will ruin your work piece. This is generally a good practice when painting anything that is made from plastic with some being worse then others.
