I've now ordered up a 1 gallon (!) can of Sherwin Williams Dimenso sprayable stuff.
It's the blue in this pic:
Paint arrived. And applied!
Looks much more up to date now than the green.
If anyone else is going with this same product, I've got to give it a thumbs up!
Applies very easily and forgivingly. You'll want to try and do it all in one coat.
Put it on WET WET WET, just to the point you think it'll run. Testing ahead of time is the key there.
If you put it on too dry, you won't get the hammer effect.
Obviously has to be sprayed. I used a very small gun with a 0.7mm tip. Took a hella long time of course, but I wanted the control for getting into tight places and not flooding it.
Guess I could have whipped out my big gun as well - but who wants to clean up twice.
Work fast as you can, as the dry time (to touch) is about 15 minutes after it's sprayed! So don't leave a dry edge to come back to if possible.
Pot time is probably fairly high as it's not reduced, and non catalyzed. Didn't want to test that theory though.
Any questions, I'll answer best I can.
