I have a 17” Jet drill press that while very nice and reliable, has a shortcoming in the adjustment of the table for part positioning .<o></o>
The table once the clamp is loosened, rotates on an of center point to allow X and Y position of the part.. But once positioned, and the clamp retightened, the table moves up to 1/8” form where you had it aligned.<o></o>
While I likely could address the issue directly, and may at some point. I decided a compound cross slide table from Phase II would be a better endstate in regardless..<o></o>
<o> </o>
ENCO had the free shipping this month, and the Phase II cross slide table was on sale as well.. http://www.use-enco.com/CGI/INSRIT?...MKANO=352&PMKBNO=3083&PMPAGE=18&PARTPG=INLMPI<o></o>
On sale from $215, to $125 plus free shipping.. Not bad..<o></o>
I received the item today, 4 Biz days after ordering. <o></o>
This is my 15[SUP]th[/SUP] ENCO order and the second of a large item weighing over 35 lb.<o></o>
Previously I ordered my ENCO 6” Milling vice http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=404-1629&PMPXNO=30821129<o></o>
Which arrived on time but in a damaged packaging, later found to be missing the handle…<o></o>
<o> </o>
So today the package arrived upon first look, as I feared, it appeared the box had been dropped one or more times in transit, and there was packaging damage,, JUST like the vice.<o></o>
<o></o>
<o>
</o>
Opening the box and I found limited shipping protection <o></o>
<o> </o>
The handles rotated and it appears that nothing was bent in the transit.<o></o>
The included parts list, indicates, all parts were accounted for, so both those things are looking better than my last large item from ENCO.<o></o>
<o></o>
Overall, the item is protected ok from rust in shipping from chine with heavy cosmoline and some oiled paper.
But finish is not top notch in any way, and lesser quality then I have seen on other Phase II products.<o></o>
<o> </o>
Loose ill-fitting feed screws and handles.<o></o>
Corroded parts<o></o>
<o></o>
Very poorly machined parts<o></o>
Casting flaws that do effect fit of the gibs<o></o>
[URL=http://s258.photobucket.com/user/Marquez_Racing/media/Smithy/Phase%20II%20Cross%20Slide/SAM_0123_zps36264940.jpg.html][/URL]
<o></o>
[/URL
[URL="http://i258.photobucket.com/albums/hh245/Marquez_Racing/Smithy/Phase%20II%20Cross%20Slide/SAM_0124_zpsb002c0ef.jpg"][URL=http://s258.photobucket.com/user/Marquez_Racing/media/Smithy/Phase%20II%20Cross%20Slide/SAM_0124_zpsb002c0ef.jpg.html][/URL]
<o></o>
Gibs that are grossly mis-adjusted, and at first attempt not correctable due to gib screws that will not turn.<o></o>
This turned out to be casting flaws in three of four thread gib adjustments. That will require running a tap though them to clean up and new gib screws.<o></o>
<o> </o>
All That said…….. for the buy in….. I believe it will end up being an ok deal..<o></o>
I have several hours of work to get it in useable shape, and will need to order 8 gib adjustment screws and lock nuts to make it work.<o></o>
Plus some T nuts that did not seem to make it on the last order (my fault, not ENCO)<o></o>
As it still free shipping on orders $99 or more, and or 15% off on orders $149 or more though this Friday… I’ll have to see if I “need” enough stuff to make that cut, or just pay shipping.<o></o>
<o> </o>
Thanks for looking<o></o>
<o> </o>
Erik<o></o>
<o></o>
<o> </o>
<o> </o>
<o></o>
<o>
</o>
<o> </o>
<o></o>
<o> </o>
<o></o>
<o></o>
[/URL
<o></o>
<o> </o>
<o> </o>
<o> </o>
Erik<o></o>
<o></o>
