- Aug 19, 2017
- 126
I got one of these and have not had any issues, I did add an external cooling fan to it a few years ago, The internal fan will cycle based on a temperature reading and loud. Anyhow my buddy has one and he replaced a couple of large Capacitors some time ago after talking to service rep. That was the fix and he no issues. Just had another failure, See Joe's note below.
Anyhow, figured to post and see if any of you had experience on these to assist. He's using a back up rotary converter at the moment as he fishes for a solution. Spendy to buy new one, and then repair this one as back up.
Joe says -- "The Phase Perfect model is a DPC-A10. The symptoms are random dropping out of the contactor, accompanied by a blinking red LED on the control board. Normally, it would be solid green when things are working. When I power down and then back up again, sometimes the fans never turn off and the contactor never engages. If I power it down again, it may come to life as normal, but then drop out after seconds or minutes. Sometimes it may take a few hours. The fans don't come on so I don't think it's a global thermal issue, unless there is a local component that's thermally-intermittent"
http://www.phasetechnologies.com/home
https://www.ultimategarage.com/shop/part.php?products_id=3024
