That's not a great idea, use the forward reverse built in the VFD.So could this switch be used for forward and reverse ( I believe it can) and the just get the vfd and use this switch with it?
Just to be clear, I order the for parts above and then should have everything needed to get it wired up, be able to control rpm and forward and reverse.On a belt drive single machine, a VFD is probably the easiest and the variable speed will come in very handy. Installing a VFD on a mill is very straight forward. WIre the VFD to single phase power, wire the VFD motor outputs directly to the motor, replace the current direction switch with a simple FOR-OFF-REV switch with two contact blocks (used to switch the VFD low voltage direction inputs), add a speed pot or use the one on the VFD. QED. It will also be quite a bit less expensive then a RPC unless you put together something yourself. Mount the VFD away from any chips, some people will mount them in the base.
The Teco L510 is a basic VFD, manual is very readable, has a warranty and also tech support. Otherwise you can ask questions in this forum and get your questions addressed.
or
Potentiometer: 5k ohm, 22mm, black (PN# ECX2300-5K) | AutomationDirect
ECX2300-5K - Potentiometer, 5k ohm, 22mm, black. Legend plate ECX2640 purchased separately.www.automationdirect.comLegend Plate: "0 to 100 scale" (PN# ECX2640) | AutomationDirect
ECX2640 - Legend plate, plastic, black field, black background, white engraved text, legend plate markingwww.automationdirect.com
