Plan Drawings Wanted For
speedre9
Aug 26, 2013
167
Anyone have access to measured drawings for a small Bending Roll Machine. When I say small I mean no bigger than three inches wide between the side frames. I have seen machines made from Aluminum that are for model builders and Jewelry makers that look fairly easy to build. I would like a build like that. Anybody know where to get some nice drawings or measured diagrams??:))
Speedree ,
It might be possible to get drawings of a hand operated three roll bending machine in the back numbers of The Model Engineer, ( A British publication) The drawings I recall are all made from bright flat & round mild steel
Although the drawings are for a machine to take about 12" wide material , It was a simple enough design to scale down to any size you might wish
Sheet or rod?
I've got some plans for a rod bender that I found before I found a rusty little Diacro 1A cheap.
Let me know and I'll dig them up.
Daryl
MN
Sheet or rod?
Daryl
MN
I'm not the original poster, but I'd like to see the plans for a rod bender.
Please note the attached links. Note: I intended to build one of these or to somehow integrate the best ideas of all. But was able to score a rusty but easily re-storable Diacro 1a for a little over $100.
http://www.homemetalshopclub.org/news/13/newsletter1306.pdf
http://www.e-bookspdf.org/download/tubing-bender-plans.html
http://www.green-trust.org/junkyardprojects/FreeHomeWorkshopPlans/TubeBender-GSBates.pdf
This is the best I have for a shear. http://www.craftsmanspace.com/free-projects/sheet-metal-bench-shear.html
If you stumble on any shop built shear plans, then that would be helpful. I'm hoping to be able to do at least 16ga.
I understand that what I really should look for is a 24-48inch stomp shear - 16ga. But, I'm not quite sure where I'd find space to put it in my shop.
Daryl
MN
Daryl
MN
Hi Daryl
This is awesome... Did you ever get to build one?
Nope.
Picked up a 24inch finger brake for $400. Built a factory copy of the stand.
Picked up a $500 #2 bender with dies on a factory stand off CL.
As I was leaving he asked if I'd take his Diacro shear (no stand) with me.
I told him I couldn't afford it. I told him all I had left was $200 and that had to extend to the end of the month.
He told me to take it and mail him a check for $200 in a couple weeks.
I got really lucky!!
Daryl
MN
