the plug pictured is a 220v plug
if you are running the mill/drill on 220v, a 15 amp 220v plug is sufficient.
if you plan on running the mill/drill on 115v,
you will need to upgrade the plug to a 20 amp 115v plug and you will also need to run it on a 20 amp 115v circuit
