[4]
PM-25 Unbox and Install - Houston, we have a problem!
[3]
[10] Like what you see?
jheinen
H-M Supporter - Gold Member
Aug 4, 2018
21
My new PM-25 arrived today.
View media item 97409
Unboxed, and everything looks good.
View media item 97410
Got the stand bolted to the floor:
View media item 97412
Went to hoist it, but the pallet is in the way of the hoist. I've got the arm extended as far as it will go. Not sure what to do other than try lifting the thing by hand, which seems like an all-around bad idea. Anyone have any ideas?
View media item 97411
wlburton
H-M Platinum Supporter ($50)
Jan 8, 2013
142
Slide it over to the right on the pallet and cut away the left side of the pallet.
jheinen
Aug 4, 2018
21
Solved. with the chain fully extended I could reach the lift straps. I eased it up and slid it to the end of the pallet. Now the problem is that the lift straps are too long to allow for enough clearance of the hoist to fit where it's going to go. I'm putting it under a loft in my garage, and there's about seven feet of headroom. I'll have to get some shorter straps so that it lifts close to the top of the machine.
jheinen
Aug 4, 2018
21
It's set up. Cleaned off the goop that was on it and it RUNS! :p The alignment pins I made helped greatly with getting it set on the stand. Now I guess I need to tram it and set up the vise. I supposed I should wait to make chips until the oil I ordered arrives? Also, any tips on removing the chip guard? I can see already that it will be a pain to have it there.
View media item 97414
T Bredehoft
Dec 27, 2014
2,833
Remove the guard mount, remove the vertical shaft, reinstall the mount. Presto Chango. The swrich that is in it is normally closed, so with the rod out the circuit is complete.
Norseman C.B.
Active Member
Dec 21, 2013
239
Didn't know you were on this forum J, the last question you asked on
the blade smith's forum will really get the answers you seek on this one, have fun with it..........:beer:
jheinen
Aug 4, 2018
21
Ok, got the mill trammed to within .0005" across about 8". I then tried to mount the vise, however the T-bolts supplied with the 5" high-precision vise are too large for the T-slots on the PM-25. How have others dealt with this? I'd try milling the bolts, however it seems that I'd need the vise to do that? Just buy smaller T-bolts? One other issue, the whole thing wobbles a little. I have the stand bolted to a concrete floor, however it still tilts back and forth a bit when I push on it. Is that going to be a problem, or just live with it?
**UPDATE** I found two t-bolts in the toolbox supplied with the mill which solved the problem!
jheinen
Aug 4, 2018
21
Is the 5" vise too big for this machine? I thought I read that the 5" was best, but the manual says a 4" is suitable.
coffmajt
Sep 25, 2013
201
You have at least a couple of choices on the rocking - either get some shim stock and fit underneath each corner to stop the rocking or fit the base with some rubber feet with adjustable studs. I use the rubber feet on my full size mill and it stays level without any fuss. Jack
jheinen
Aug 4, 2018
21
Thanks. I think I'll give shims a try, as I really don't want to pull the mill off the stand if I don't have to
jheinen
Aug 4, 2018
21
Yay. Turns out I had a jar of shims sitting on the shelf. Rock solid now.
[6]
[5] [7]
