[4]
PM 727M Enclosure
[3]
[10] Like what you see?
jaxpc
Newbie
May 1, 2018
5
Likes
0
#1
I just received my 727m, but I can't set it up until I do some shop construction. I'm not going to be using liquid
coolant. I would like to contain a lot of the chips if possible. Are there any plans for a simple, cheap, chip enclosure?
Or semi-enclosure, to keep my shop a little cleaner. A full CNC enclosure will not be needed. Thanks
Ray C
Platinum
Staff member
Nov 16, 2012
5,215
Likes
1,443
#2
This probably is not as glamorous as some setups but, I use little spring clips to hold pieces of cardboard as deflector shields. The cardboard that comes from cereal boxes is ideal. I have a couple wooden dowel rods and stuff them into a couple T-slot nuts for quick positioning. This localizes the cleanup immensely and is universally flexible -and cost essentially nothing.
Ray
Clock work
H-M Supporter - Gold Member
Nov 25, 2016
164
Likes
118
#3
I do something similar to Ray and have some clear panels screwed to on/off magnets I can move around. Stuff still flies... I keep meaning to put a shower curtain up I can draw into position when I know I have an operation with a big throw and out of the way the rest of the time. Also unglamorous though.
stioc
Active Member
Feb 22, 2017
174
Likes
387
#4
I use a few deflectors to keep much of the mess off the floor. The metal ends of the table come off with half a twist of the bolts holding them in place if I need the room for large pieces (which is rare).
jaxpc
Newbie
May 1, 2018
5
Likes
0
#5
Some great ideas so far. I never thought of a shower curtain type setup.
jaxpc
Newbie
May 1, 2018
5
Likes
0
#7
Thanks for the links. I have seen a few of his You Tube videos. His PM 727m CNC project is pretty advanced. Some of the first videos
in that CNC series are good. The machine unboxing and set-up. But, his enclosure is full on CNC style and beyond what I need right now,
as a beginning mill user. They are good videos. CNC is far in the future, for me.
ryan79
New Member
Sep 11, 2014
27
Likes
16
#8
been working on that myself sense I got the machine. been a long road hope it pays off in the end. will try to get up pics.
jbolt
H-M Platinum Supporter ($50)
Dec 3, 2013
1,507
Likes
1,472
#11
On y pm-932 CNC conversion I only have a half height enclosure. I works fine for most things even with the high volume of coolant I run. I do occasionally get some spray over the top but not enough to fret over. I started with a PVC pipe and shower curtain setup and later changed to a frame from 8020, aluminum sheet sides and lexan sliding doors. It is still an open top enclosure. I found that the coolant eventually makes the shower curtain material hard and brittle.
https://www.hobby-machinist.com/threads/pm932-cnc-build.21442/post-432102
ryan79
New Member
Sep 11, 2014
27
Likes
16
#12
started off as something that was suposto be simple and quick/ but then I decided to wrap it in aluminum and add the chip pull out draws, what was I thinking. still need to make some back braces, side guards at the table edges and install the z axis motor, its a 3 phase gear motor and 150rpm whit a vfd 110 to 3 phase 1/4 hp.
jaxpc
Newbie
May 1, 2018
5
Likes
0
#13
Thanks Ryan. That is more along the lines of what I was thinking. Yes, a little higher on the ends would work for me, as well.
My brother is a aircraft homebuilder, and I might talk/force/bribe him into building me a enclosure. Your floor is really nice.
I can see why you want a nice enclosure. Love your rolling cart by the way.
[6]
[5] [7]
