- Jan 26, 2018
- 26
I've been researching into Bolton Tools, Little Machine Shop, Wholesale Tools, Grizzly, and especially Precision Matthews for months and it seems that Precision Matthews cannot be beaten because of that 3 year warranty and from several comparisons on Youtube and multiple forums across the internet, it seems abundantly clear that Precision Matthews has the best quality control.
With that in mind, I have some electrical limitations for the kind of machine I'm looking for and weight restrictions. I have my work area on the 2nd floor of my house and I do not have access to a 220V outlet. Installing the 220V breaker in the basement and then running the wires to the 2nd floor, it's just out of the question. If the machine weighs more than 800lbs, I don't see any feasible method of getting that machine up the stairs because there is no "safe moving company" that would service Northern Maine, nor any moving or rental service that could provide me a power life hand cart to make the trek up the stairs, within a reasonable distance. I'm more than willing to take the machine apart and then piece it back together on the workbench.
I do however have a possible solution to the 220V problem and perhaps this will help others, there is one contraption that one company came up with, that seems to have some "idiot proofing" built into itself so that you may use "2" 110V outlets (not from the same breaker) to create the necessary 220V, as seen here (without blowing up the breaker box):
Video:
Store Page: http://www.steam-brite.com/advanced_search_result.php?keywords=electric+car+charger
I want to use the machine for mostly aluminum and polycarbonate materials, which means I need a much higher RPM, I'm also dealing with some very small holes and slots, less than 1mm in diameter, frequently. As much as I would like to have the PM-30MV's 1HP extra, I'm losing 750 RPM from the PM-727V to get it. Is there any "simple" modification to upgrade that motor, while maintaining the variable speed controller, and getting more RPM?
Looking for input on this, I would rather just buy the best machine "the first and only" time.
Video:
