[4]
PM mill which one
[3]
[10] Like what you see?
jsh
Active Member
Apr 6, 2016
59
Decisions, decisions. I have not called them but will do so.
Thought I would ask the crowd here,25MV,727M,727V.
I am pondering on which one. I do and don't understand all the differences.
I am going to go ahead with DRO on what ever I get. Some say it is an extra, others say how did I ever get by with out it.
I think I am going to build my own base. I have plenty of angle iron,wire welder, chop saw, sanding wheels etc, to top that off there is a powder coating company just a mile from the shop I have access too.
I am going to need basic tooling as well, so there is some more. I have a few odds and end mills, a so so vise.
Thanks for any input.
Jeff
Rickwjenn
H-M Supporter - Gold Member
Jun 11, 2018
66
I would go for the 727 over the 25 just due to size and mass. Heavier is better IMO. Go for the variable speed spindle as well.
Btroj
Active Member
Sep 11, 2014
31
I just got my 833T and can assure you that the DRO is all it is made out to be. I can’t imagine not having it. Quality work can be done with the dials but the DRO just makes it easier.
Go with heavier. And a good vise is well worth the money. I got a Glacern and couldn’t be happier.
And you can stop by and see mine anytime.
shooter123456
Jan 20, 2016
396
I have a PM-25 and I am very happy with it. I can't say if it will be better than a 727, but it meets my needs very well. I have it CNCd and I haven't found its capabilities to be limiting to me. I work mostly in aluminum and I was able to get it removing 3in^3/min. The accuracy has been excellent and most of the components are very well made. I have a 2 HP servo motor on the spindle now and the mills rigidity hasn't been an issue with heavy cuts. I have no doubt the 727 could take heavier cuts though, it comes at the cost of travel and up front price. I have recently been using my machine for more production oriented work and I have been taking up much of the travel. If I was running it manually, I can't imagine I would use all of the travels that often.
I wouldn't shy away from building a base. You can save a few dollars and get exactly what you want. The hard part is usually getting the height right and I have heard others have trouble with the standard base height. Personally, between the 3, I would get the PM-25 if I was going to CNC, or the 727M if I was going to keep it manual. I don't think variable speed is critical on a manual machine the way it is on CNC. I would save the extra dollars over the variable speed and spend that on the tooling and DRO.
On that note, a DRO isn't absolutely required, but I would highly recommend it. When I had my X2 mill and I was using it manually, my productivity shot way up when I added a DRO. I was able to do things easily 3x as fast and more accurately. I also was able to figure out that when I locked my axes, they would shift a little bit. With the DRO I could account for that beforehand. It usually wasn't much, maybe .003" at the worst, but it helped make my work more accurate.
For vises, I have an el cheapo 4" kurt knock off vise from ebay (Probably $100 or so) and it is alright. The fit isn't fantastic, but it holds parts tightly. It isn't as accurate as I would like, so for first operations where I am removing extra material it is excellent, but for second operations where it needs to hold the part accurately, it isn't the best. For those operations, I have a 3" toolmakers vise (probably $60 on ebay) and it is very accurate. I have measured it on a surface plate and it is flat and parallel farther than I can measure with a .0005" indicator.
I hope that helps! If we can answer any specific questions, just ask and I am sure someone will have an answer.
Rickwjenn
Jun 11, 2018
66
I would absolutely go for DRO if you can't do CNC. The digital readout to the .001" even it if only accurate to 1/2 that is WAY BETTER than dials IMO. Most parts don't require that accuracy and you will be much MORE productive. So what if a part is off by .001 to .002"? Unless you are making internal engine parts it does not matter...
Get the DRO or go CNC...
ScottLoudon
Newbie
Sep 26, 2018
2
I have the PM727mv. Power feed and DRO purchased with machine. So far I am pleased with it. It's only a couple months old, no real issue,s other than the X axis power feed needing a new brush. PM sent out quickly without charge. Would definitely recommend.
[6]
[5] [7]
