It does both, cuts power to the spindle (acts like an e-stop) & brakes the spindle with drum type shoes inside the spindle pulley. I can actually adjust the gap between hitting the micro switch & applying brake pressure. On mine I have it set where I can slightly press the pedal & it will cut the spindle power, then if I press a bit more the brake will then engage.
