I've received my PM1340GT in early September and only now reached a point where I can go over the machine properly (time spent finishing up other projects, getting the stand welded up and the lathe moved into position.)
One thing I noticed is that the compound doesn't move smoothly through its full range of travel. The last 4-5 revolutions at the end of travel (going clockwise) have definite binding. I tried a full disassembly / clean / lube and it didn't seem to help any. The gib adjustment also doesn't seem to have any affect. I now have the gibs pretty loose and the last 4-5 revolutions still have a 'kink' to them.
So I guess I'm looking to confirm that this isn't normal and the slide should travel smoothly throughout the entire range. Anything else I should try prior to contacting PM?
