- Jul 13, 2014
- 1,051
Coming to TX in 2-3 months. This will replace my SBL13, and maybe my ACER 1236. Ulma Doctor, the Baby Jet 1024 you sourced for me is not going anywhere. Still love that little green lathe that could.
PM-1440TV High Precision Lathe With:
Complete solid one piece cast iron base
Back Splash Guard
4 Way Tool Post
Tail Stock Dead Center
Feed Rod Clutch (To prevent overloading and usingcarriage stops)
Steady Rest
Follow Rest
Coolant System
Owners Manual and Parts List
NTN, NSK, FAG, or NACHI Spindle bearings, with +/-.0001" Max Spindle Runout
Reducing Sleeve for Headstock Dead Center
Thread Chasing Dial
Everything Needed for listed Inch and Metric Thread Pitches
Foot Brake
5 YearWarranty
Easson ES-12B DRO Set, 200x1000mm Scales:
GS-31 200mm High Resolution Cross Slide Slim Scale
GS-10 1000mm Long Scale
Specifications
Back Splash Guard
4 Way Tool Post
Steady Rest
Follow Rest
Coolant System
Thread Chasing Dial
Foot Brake
5 YearWarranty
Specifications
Swing over Bed | 14” |
Swing over Cross Slide | 8 3/4” |
Swing over Gap | 20 3/4” |
Distance between Centers | 40” |
Width of Bed | 9” |
Spindle Nose | D1-4 |
Spindle Bore | 1 9/16” |
Taper of Spindle | M.T.#5 |
Spindle Speed (2-steps)) | 25 ~ 2500 RPM |
Leadscrew Diameter | 15/16” |
Pitch | 4 TPI |
Inch Threads | 3 ~ 56 TPI (32 kinds) |
Metric Threads | 0.4 ~ 7.0mm (32 kinds) |
Longitudinal Feed Range | 0.0026”/rev ~ 0.0368”/rev |
Cross Feed Range | 0.0013”/rev ~ 0.0184”/rev |
Cross Slide Travel | 7 7/8” |
Compound Rest Travel | 3 3/4” |
Quill Diameter | 1 9/16” |
Tailstock Quill Taper | M.T. #3 |
Quill Travel | 4 7/8” |
Main Motor | 5 HP, Three-phase, 220V |
Inverter Drive | Yaskawa V1000, 7.5HP |
Coolant Pump | 1/8 HP 3ph |
