I purchased a 6" rotary table 4th axis with my PM45 CNC mill. I recently tried to use the table and noticed that the table had free play on the axial shaft. I turned the table over to see the spanner style nut on the bottom of the table and proceeded to adjust the the nut in hopes of snugging the table up. With just the slightest torque on the nut the table will not even turn. Today I disassembled the table from the base to inspect the components. Unfortunately this is my first rotary table and it looks pretty straight forward but I do not know if a washer is missing or something as I do not have a schematic. Also I was shocked to see that there was no bearings holding the shaft in alignment. Any help would be greatly appreciated
thanks
thanks
