- Mar 5, 2019
- 216
So, got my new mill all setup, pm727v. During my setup checks I discovered that there is a variance of a few thousands between the quill wheel, the dro and a dial indicator I setup. It doesn't always seem to be consistent, I have to down feed several hundred thousands with significant inconsistency, almost like the downfeed is slipping. But then it gets better. Better is defined if I move the handwheel .010 the dro will read .0085'ish. the dial indicator is fairly close to the dro with maybe a .005-.0075 variance. And it varies a little as I turn the handwheel so I cannot simply account for the variance.
I cannot see anything to do about this so I am open to suggestions.
Thanks
Thanks
