Pm932 Base Mod
65Cobra427SC
May 18, 2015
231
Note: Thread was renamed to PM932 Base Mod
Wasn't sure what else to call it but the picture shows how oil can form a pool within the indentations along the sides of the PM932 mill. Not sure if other mills are this way but they could be since I think the indentations are there to help strengthen the casting. But in my case they helped create a problem. The oil found it's way under the paint during the boat trip from China and the end result is the filler underneath the paint became oil soaked, causing the paint and filler to separate from the cast iron. My plan is to clean those areas down to the metal so I can repair and repaint the affected areas.
Since I have to do the work anyway, I'm also thinking of filling those indentations with epoxy in order to prevent any further pooling. I could even shape the epoxy so the oil runs off the side in a specific location. Just wondering if anyone else had this problem and/or has a better idea how to fix this. Thanks.
I am not sure epoxy is your best option. I would look at Fiberglas reinforced bond. It cures up pretty hard but can be sanded and shaped.
Not committed to epoxy but would want to use something that won't separate from the metal and isn't going to be affected by oil which eliminates the majority of products. Considering where that area is located, it will likely get oil soaked on a regular basis. I also can't make that area completely level so the oil doesn't work it's way elsewhere... i.e. under the bolt heads. I searched online for options... hadn't considered fiberglass but not sure I want to go there. Now I'm considering Lab-metal by Alvin Products which is a 1-part filler... goes on with a putty knife... air dries in a few hours... and is "not affected by petroleum-based oils or gasoline".
My 12z has similar troughs and I watch them when pulling the oiler handle. When the oil starts oozing out from under the saddle I figure I've got enough oil in there. :)
I've not had any problems with them though, and I like the fact that they catch oil for later sopping up with a paper towel instead of running down the side of the machine.
Interesting... thanks for the input. In my case the oil would just run down the sides into the channel around the top of the base, then into the container where it belongs.
Why not just bondo? Essentially polyester resin with a filler made of chopped silica. That is what all the other voids in the casting (that you can't see because they are painted over) are filled with.
Since cast iron isn't smooth, it was obvious a filler was involved even before I purchased the machine. And most old cast iron machines had some kind of filler, even the Bridgeport, but it's the type/quality of the filler that's important. I expected less from a mill made in China than Taiwan but I didn't expect to be removing softened filler from a new machine either. But I'm not regretting my purchase in the least... things like this happen and even though my situation is worse than most, I can fix it. It's just it wouldn't make sense to do all this work only to use another filler that could end up doing the same thing. Bondo, as well as other fillers of the same type, contains talc which absorbs moisture... and besides, they are not oil resistant. It's the paint that shields the filler on these machines. But if the oil finds a way under the paint, the filler will absorb it and the process eventually spreads.
The reason my situation was much worse is because the oil was working it's way under the paint along the entire top edge where the paint ends. There was actually a gap between the paint and the cast iron all along that edge and the filler was still soft into the trough. I knew how much of the paint/filler to remove because the filler would gradually get harder. So instead of using Bondo, I'm hoping Lab-metal will do the same but it's resistance to oil will at least help prevent this from happening again.
There were multiple complaints about Lab-metal online so I decided to purchase it locally instead. Tried 2 different retailers and in both cases we opened the cans and found they were only 2/3 full and as hard as a rock. The label says the factory can has a 2-year shelf life but there is no date or date code on the can or the label anywhere, duh! So none of the retailers know how old they are. Went back to the epoxy idea and although it's working very well, it's taking longer for me to finish than I planned, although I'm juggling it between other projects. I'll post pics within another couple days.
The base mod is done, including paint and a two part clear coat that's chemical resistant. Now I can get everything else connected and I'm ready for the lathe. In addition to modifying and repainting the base, I fixed a damaged area on the back of the column where the DRO mounting bracket gets attached, and repainted the long cover that bolts to the back of the column. They put primer on one side of that cover, then painted the opposite side... so there was no primer under the paint and it was peeling off. Now it's done right.
One thing the pictures don't show is I removed all the paint and filler around the trough and bolt holes as well. Otherwise they should be self explanatory but I doubt anyone else is crazy enough to do this. It was very relaxing for me and now the oil will just roll right off the sides and into the oil channel on the stand.
PM932 001 Remove Paint & Filler.jpg PM932 002 Fill Trough with Epoxy.jpg PM932 003 Create Slope with Epoxy.jpg PM932 004 Create Slope with Epoxy.jpg PM932 005 Primer Coat.jpg PM932 006 Painted Base (Front).jpg PM932 007 Painted Base (Left).jpg PM932 008 Painted Base (Right).jpg PM932 009 Painted Column (Rear).jpg PM932 010 Painted Column (Rear Cover Plate).jpg
