- Feb 2, 2017
- 1,234
My new to me Graziano 12S came with a pneumatic collet closer. It clamps, but doesn't release unless I vent the line. There's quite a bit of hissing coming from the shuttle valve in some positions, so I suspect a leak in the valve. The hoses could use replacing, but I don't think they are preventing it releasing.
It appears to be a commercially made unit, and pretty well made at that. It has a little shiny label, but the printing is all worn off. I've looked online for information on something similar with no luck so far. I'm trying to find what pressure to set the regulator, as well as any information on troubleshooting operation.
The bearing retaining nut definitely needs to be replaced--the threads are in bad shape and the hole for the spanner is jimmied. The nut for the draw tube needs to be replaced as well--again thread issues. Making replacements will be a good "bonding" experience.
Any suggestions on where to look for information would be appreciated.
