Pole mounts for new drill and old belt grinder.
th62
Aug 22, 2014
315
I have a smallish shed, 5m x5m so space is limited. halfway along either side wall is a 6" post that juts out the same amount, this precludes largish machines being placed in front. When last in Aldi I spotted a small bench drill which I though would do well next to the pedestal so I mounted the bench drill on a bracket I made that clamps around the pole. I also included a couple of stickouts on which to mount two drill sets.
While I was at it I made up a similar clamp for the other post and mounted the belt grinder I made a while back.
Both work quite well, free up bench space and use space not normally used.
Looks great! And uses up unused space to boot. Would it be possible to see a close up of the belt grinder you've made? Looks nice!
Thank you so much! May have to copy you somewhat. When I get caught up......
