Possible happy outcome with an economical lathe chuck
jmarkwolf
Nov 9, 2012
556
I finally settled on a new 8in lathe chuck for my 10in rotary table. I couldn't justify a spendy chuck for occasional use in my home shop, and after scouring the on-line universe for a good candidate, I realized that there is no way to anticpate the level of quality on import chucks under $500 or so, sight unseen.
The chuck I settled on is from a company called CME tools for $140. After comparing the description and on-line pricing on many chucks, the clincher for me was that CME laser etches their name on the chuck. No no-name chucks for me! :)
I was about to place an on-line order from the CME EBAY store for $180 delivered, but I noticed that CME is actually located in a suburb of Detroit, about 45mins from my home. I called them to see if I could simply drive over and pick it up. They assured me I could, saving shipping charges!
After un-boxing, the first thing I did was to plug the chuck key in and test the jaw movement. I didn't feel any apparent grit as the jaws opened and closed, although I could feel the distinct pinion gear mesh on the scroll. The jaws closed nicely with no apparent asymetric gaps between jaw edges.
After learning from the pages of the Hobby Machinist forums how to examine, dismantle and clean a lathe chuck I unboxed it and set about the task.
The chuck was covered in a light film of oil, which is easier to clean off than cosmoline that I was expecting to find. I was pleasantly surprised to find none of the sharp edges and burrs that many other reviews reported on other economical chucks. Curved edges were nicely rounded, and straight edges were all nicely chamfered.
As I dismantled the chuck I did encounter some wet sandy muck on the internal parts, as I have seen in on-line videos. After rinsing and cleaning the parts and re-assembly, I'm feeling quite optimistic I may have a reasonably usable lathe chuck for not too much outlay.
Will report here when I get it all back together and bolted up to my rotary table, for which I'll likely need to fabricate some t-nuts.
Pics below:
288092
288093
288094
288095288096
Good for you! Even high end chuck makers sometimes leave debris and burrs in new chucks so I've learned to trust only myself with new or used chucks. Take them down, wash and lube and assemble it right. Then you can trust it.
Looks like you got a nice chuck for not much money. Congrats.
It's always nice when you get a reasonable price piece of kit and it works well.
The main body looks to be nice solid walls they don't appear to have skimped on the amount of material in it :)
Stu
I have a brother to that one.
As do I. Mine is an older one though, not made by Sanou, well not marked anyways.
288190288191
Let us know what the run out is when you find out. Always nice to get more than you were expecting. Mike
Thanks for sharing and very interested in your after use review as well if you wouldn't mind.
My intended use for this chuck is as a dedicated accessory for the rotary table.
I will be utilizing a 3MT/straight shank "plug" to align the center line of the chuck with the center line of the table. The taper portion will be snugged in the center hole of the table, and then by closing the jaws on the straight shank portion of the "plug", the chuck and the table alignment will be quite good (I think).
Consequently, , I won't have the opportunity to measure run out in the practical sense, such as on a lathe.
I got a CME 4-jaw independent to use on my lathe a few months ago. I found the quality very good.
-Ed
