- Sep 22, 2019
- 89
I decided to check the runout after boring out the upper part of the R8 spindle.
The Morse taper arbor PM supplied had at most two ten-thousands runout. (See attached video)
A 1/2" end mill
shaft in the Interstate collet had about one thousands runout.
I clamped a 1X2 board in the vise. Using the Y axis handle I pressed the board hard against the end mill. There was about one thousands deflection.
I am not familiar with typical runout values. These seem pretty good to me.
I have been of the opinion that a sloppy fit between the threaded end of an R8 insert and the spindle would have no adverse affects on performance. I think wedging the insert into the R8 taper with the draw bar is what produces stability, not the upper end of the insert.
A 1/2" end mill
